Hallo Guy’s,
I hope you can help me with a simple question.
If I want to publish sheets to PDF. And I choose for single-sheet file he never asks for al location
I have always to go on the PDF publish options to choose a location
Only if I choose the multi-sheet file he pops-up with a locations chooser
Is there a option that he always ask for a location single and multi sheet file’s
some tips click here
for single-sheet file & Multi sheet is it same location???? please upload print screen of publish options
Jayhar.M.J
Do you need to save in the same folder where the file is?
The place to choose file location is the same whether you are publishing multi-sheet or single-sheet (under 'publish options information')
Some pdf-writers always have a pop-up asking for file location during the plot process. Autocad default pdf writers will not have a pop-up, they will always write to the location in 'publish options'
