Publish error Internal error null pointer
Hi,  When publishing a set of 5 sheets to .pdf, AutoCAD 2017 publishes the first 2, and then I get an error for the remaining three sheets.  The error states "ERROR: Internal Error: Null Pointer"
A quick Google search indicates that there would be an issue with the .dwg to .pdf plotter; and to replace the file in the plotter manager.  However, this answer is based on CAD 2010, and the .dwg to .pdf file was just downloaded with the 2017 exe file.  Moreover, it does not make sense that 2 out of 5 sheets can be converted to a .pdf file.
Any thoughts?
Thanks!  It is not too much of an issue to plot each sheet separately since this project set is only 5 pages, but it will be a problem for larger files.
pendean
Community Legend
Community Legend
depends on what you are using for pagesetups in PUBLISH: it's clear you are not using one but many. The error message usually means one of your pagesetups being used is referencing a migrated older PC3 file.
"Adobe PDF" is not an OOTB option, that came from somewhere and is the culprit.
Thanks! I did have different printer settings... now everything has been normalized between the print set-ups and the full set plots according to the "publish" command. However, it is making each page into an individual .pdf, rather than one .pdf with multiple pages. There must be a setting I am missing?
Best Regards,
Erin R. Collins-Cecil
Architectural Designer / Project Consultant
[Description: B&Wemail]
3631 Route 22 East
Somerville, New Jersey 08876
(908) 534-9111 / (908) 534-9155 (fax)
Direct (908) 691-2390
Toll Free (844) 332-3854
Cell (908) 655-1511
The information transmitted by this e-mail is intended only for the addressee and may contain confidential and/or privileged material. Interception, review, retransmission, dissemination, or other use of, or action upon this information by persons or entities other than the intended recipient is prohibited by law and may be subject to criminal and/or civil liability. If you received this communication in error, contact us immediately at (844) 332-3854, and delete the communication from computers or networks. Although this e-mail and attachments are believed to be free of viruses or other defects that might affect any computer system into which it is received, it is the responsibility of the recipient to ensure that it is virus free and no responsibility is accepted by Berman & Wright for any loss or damage arising in any manner in the event that such a virus or defect exists.
pendean
Community Legend
Community Legend
A multi-page PDF (one pdf file, many pages) is only an option when you select the PUBLISH TO PDF choice and not PLOTTER NAMED IN PAGE SETUP in PUBLISH command's pop-up.
Thank you! I cannot believe I missed that.
Best Regards,
3631 Route 22 East
Cell (908) 655-1511
