AutoCAD Forum
Locating blocks in a drawing
5 REPLIES 5
ctnycc
7973 Views, 5 Replies
Good afternoon,
I have a query on blocks.  I want to find a block in the drawing that has a certain tag value for the attribute.  I tried using quick select and was surprised it dodn't have htis opotion.  Can anyone suggest a quick way to find the relevant block?
Thanks in advance
Colin
5 REPLIES 5
qnologi
in reply to: ctnycc
So I understand you correctly, you "do" or "don't" know the name of this block that has these "certain tag value for the attribute"?
You could type "RENAME" go to blocks and find the name of this "block", then cancel out of this command.
Then re-insert this "block", click on the block, type DDATTE and read it's TAG value.
qnologi
ctnycc
in reply to: qnologi
Hi qnologi.
I do know the name of the block which is OSL.  It is the value of the attribute i wish to locate in the drawing whcih will show me the location on the map.
I have attached a sample, the block position is placed by the coordinates from a script file which i have run to save the bother of plotting every single point,(3000 points) on the map.
Regards
Colin
imadHabash
in reply to: ctnycc
i suggest to use FIND command line. AutoCAD FIND button will go direct for the certain number you need.(see attached)
Imad Habash
ctnycc
in reply to: imadHabash
imadHabash
in reply to: ctnycc
You're Welcome.
Imad Habash
Forma Design Contest
