Publish doesn't publish
BeKirra
BeKirra
Usually I use a PDF printer driver when creating PDF files.
I don't use publish often.
I now found that the Publish doesn't work (for any drawing file) - no PDF can be created at all.
The publish error report shows that "ERROR: Device not found".
Thanks in advance.
undefined
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Replies (10)
imadHabash
Try to prepare and depend on page setup manager.
Imad Habash
pendean
Community Legend
Community Legend
so... look at the top of that pop-up you screenshot, instead of the bottom: change the PUBLISH TO and do what you need. PLOTTER NAMED IN PAGESETUP is the option that lets you change number of copies in case you were wondering.
BeKirra
Thanks to both of you.
I now created a new drawing file with a page setup "Publish to PDF" by using "PDFcreator".
BTW There is no problem when "plot" to PDF by using the page setup above.
I also removed the "model" from the list in the Publish dialog for simplification.
As you see that the plot device has unexpectedly been overrided to "DWG to PDF" in the screenshot.
And the "Plot and Publish Details" are:
File: C:\Sending to\Publish to PDF.dwg
Category name:
Page setup:
Device name:
Plot file path:
Paper size:
undefined
X² + Y² = C²
pendean
Community Legend
Community Legend
If you created a pagesetup to use with "PDFCREATOR, then your screenshot is ALL wrong to use that. At the top of the pop-up, instead of publish to pdf you want to select PLOTTER NAMED IN PAGESETUP.
Don't get confused by the tag PDF: you want to use an external driver, so set PUBLISH to use your external driver.
BeKirra
Thanks for your help. I now use "Plotter named in page setup".
But how to set "Publish" to use exturnal driver?
X² + Y² = C²
pendean
Community Legend
Community Legend
>>>... I now use "Plotter named in page setup"....<<<
You just did.
BeKirra
Thanks again.
I asked the last question because I can't see <publish to "PDF"> working for me. Did I miss something?
X² + Y² = C²
pendean
Community Legend
Community Legend
With your desired PDF printer, you don't need that.
ampster40
Please keep following along with Dean's suggestions as it sounds like this isn't resolved 100% yet. I just want to add a side note regarding background publishing. If you have not already done so, disable it for now at least until you can get this to work (Tools > Options > Plot and Publish tab > Background processing options section, how I guided you towards this area would work for 2014 but should work for most current versions). We've encountered errors here when plotting or publishing and what works 90% of the time for those issues is to disable the background plotting and publishing options. This may not have anything to do with your current issue however, but at least you won't have to sit there for a few moments/mins after each test to see if it's working or not.
BeKirra
Thanks for your suggestion but it doesn't work for me - I haven't enabled the background plotting and publishing.
BTW My default output device is set to "PDFcreator".
X² + Y² = C²
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
