- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is there anyway to adjust the inherent proximity the program uses for the trim command? The issue I am running into is that certain line intersections will not trim easily. When zooming way in, I can determine that yes, there is a gap, but the gap is almost infinitesimally small. If my intended output for my drawing is let's say 1/8"=1'-0", then I am comfortable with my drawing not being accurate on the microscopic level. Is there a way to tell AutoCAD to not care about these tiny gaps?
Related question, I have now noticed that sometimes the trim command adds a gap after trimming. I have two lines that I just drafted, intersecting at 90 degrees. I highlight these lines, activate the trim tool, trim one line, and the other line now does not register an intersection.
help please.
