properties Pallet not working properly.
I am using acad 2019. When i select for eg 2 lines the properties pallet works properly. and it i select 3 or more lines it is not working properly. it tells no selection as shown in the attached images.
imadHabash
would you please check your CAD updates from your Autodesk Desktop App ? >> Click <<
Imad Habash
updated but still the same.
imadHabash
if you select lines first then press Ctrl+1 to show the properties palette , any changes ?
Imad Habash
vinodkl
Type in the command "PROPOBJLIMIT" and set it to "0". Now check if more than two objects are selected the properties are displayed.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
