AutoCAD Forum
Properties not working
1 REPLY 1
583 Views, 1 Reply
Properties not working. If I select an item, in this case a dimension and then click on properties the properties pop-up is blank (white screen) If I open properties first and then select the item (again a dimension) nothing changes from the defaults (General, 3D Visualization, Plot style, View, Misc)
I have just up graded to AC2014 from AC2011(new CP no AC on it) Has the properties function changed that much from AC 2011 to AC 2014 that it does not list the basic information of a dimension any more?
1 REPLY 1
nestly2
nestly2
You probably have some other software interferring with AutoCAD, frequently it's a registry "cleaner"
from the knowledge base  Properties palette blank after selecting object
AutoCAD Inside the Factory
