Hi Forum
I am working in AutoCAD 2017 and have a few complicated meshes that I am modelling with, is there any way to project a 2d planar outline of the mesh objects without having to physically trace it manually?
Regards
Jonathan
Solved by Alfred.NESWADBA. Go to Solution.
please find command _PROJECTGEOMETRY (>>>details<<<).
Is that what you are looking for?
- alfred -
Hi Alfred
Thanks for your response, unfortunately I am not trying to project to the mesh, but rather extract its planar outline with a simple cad command. In the screen captures below, the yellow geometry is a mesh, approximately 44k vertices, the white shape is more or less what im after, a planar outline of the mesh. I did this my extracting all the edges of the shape and projecting the resulting 3d polylines to a plane I created at the base of this mesh. i then have to go and try to cleanly delete the non-essential 3d polyliine to try to find the outline shape, but i often delete the wrong lines and loose the shape definition that I am looking for.
Regards
Jonathan
please try these steps:
Run command _FLATTEN, that brings your object down to Z=0.0
...this should result in an outline of your geom.
HTH, - alfred -
