After installing a Dell Port Replicator using Display Link Technology (USB 3.0), I can not open a drawing (either from cloud or local storage). The existing drawing files will not open past the regenerating model command at start up. Tried several different drawings, and installed Service Pack from support site.
We are running the latest version of AutoCAD 2017. The solution was to make the laptop screen the primary screen. There was a dialog box (OLE Object Display) to make a choice that was not visible (hidden in background). Once I made the laptop screen the primary display, the dialog box appeared, and I was able to make the appropriate selection, and the drawings opened up without issue.
Thanks for your response.
Andy
