Problems with the plan imported from Sketchup
nelu_codrean
nelu_codrean
So I have a plan that I imported from Sketchup into AutoCad and I would like to edit this plan but I can't in any way because Autocad sees it as a block/Hatch and I try the explode command but it doesn't work. Maybe someone knows how to solve it or through an alternative method maybenelu_codrean_0-1744108957617.png
imadHabash
Sometimes SketchUp exports things as groups, which AutoCAD recognizes as a block. You can try the UNGROUP command. It works fine with me.
Imad Habash
nelu_codrean
It worked, thanks for the help. Even though the solution was easy, I didn't realize it.)
