Problems with Text Formatting
fparente4XJPH
Message 1 of 8
fparente4XJPH
Hello everyone!
Please kindly, I need help.
When I try edit a MTEXT appear the text formatting bar without several commands, as can you see in the image, is a bar very simple and to edit the text appear a dialog box.
I don't know how come back to restore the full formatting bar.
Any idea?
Thanks a lot!
Fernando.
Replies (7)
Message 2 of 8
Alfred.NESWADBA
which version of AutoCAD do you use?
Does that happen only with a specific file or also with new files (based on original AutoCAD templates)?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 8
fparente4XJPH
Autocad 2018
This happen for all drawings, inclusive new.
This appear a few days ago, I do not understand why, I wait for any help or I will re install the program.
Thanks.
Message 4 of 8
user181
When you're in the editor right click on the black background and go to editor settings and then check the show options and anything else you want to show
Message 5 of 8
fparente4XJPH
It is not possible because not appear the option Editor settings 😞
Thanks.
Message 6 of 8
Alfred.NESWADBA
if you have not done any customization's to your menu you might reset your AutoCAD profile to default as described >>>here<<<.
- alfred -
Alfred NESWADBA
Message 7 of 8
user181
Set the variable MTEXTED to  Internal
Message 8 of 8
fparente4XJPH
Oh! User181 Thanks a lot!
Problem solved!
Regards.
