Problems opening a dxf file
laura1.filippini
Message 1 of 10
laura1.filippini
Hi everyone!
I'm having trouble opening a dxf file.
I cannot attach it here cause it gives an error so I uploaded it in wetransfer:
https://we.tl/t-aqEwGwEYHW
I have to work on it in Autocad but when I open it I see nothing but the plank paper (in both model and layout). Anyway I was able to open it in Illustrator but doing so I lose the layers.
Anybody can help?
Thank you 🙂
Accepted solutions (4)
Replies (9)
Message 2 of 10
cadffm
So you have a problem inside the file, it isn't a problem to open the file?
Use ZOOM
Object
LAST
HTH
Sebastian
Message 3 of 10
laura1.filippini
Hi! I tried but it doesn't work, in autocad it looks like the file is empty 😞
Message 4 of 10
cadffm
Try it again. It should work.
Start your program (AutoCAD?)
Use command OPEN or RECOVER
change the extension to DXF and select your file.
Now the file is open and the current space is MODEL.
Command: ZOOM EX
Sebastian
Message 5 of 10
pendean
Community Legend
Community Legend
I opened your DXF, in modelspace all I did was Zoom>Extents and got this below. What are you doing that you cannot find anything?
Message 6 of 10
laura1.filippini
I tried exactly what you did but nothing happens, this is what I see after executing those commands:Cattura1.JPG
I'm using Autocad 2021, maybe is it a settings problem? Sorry but I'm not very expert with these tools 😞
Message 7 of 10
a_meteni
Please checkout the attached file!
Message 8 of 10
laura1.filippini
omg thank you 😍
Message 9 of 10
cadffm
This screenshot is from another file (we can not check a file we do not have..),
the UCS is another one and it is possible the the situation is totally differently.
WE can't know it.
Please use the same file like us, open your 1.dxf, not another one.
I tested your 1.DXF (ZOOM E) with 2021.1, newest **** of autodesk labor 😉
Sebastian
Message 10 of 10
laura1.filippini
Oh yeah, actually the file "1" was just a copy of "altimetrie". I don't know what happened but since I opened the file you guys posted me the other files also work using "zoom" and "extent", so the problem is solved. Maybe it changed some settings idk. Thank you everybody!!!
