Problems measuring distances
Message 1 of 13
Hi everyone!
I've never had this problem before, but all of a sudden I can't calculate distance between two points.
When I click select the option (Tools -> Calculate -> Distance [or equivalent, I use the Spanish interface]) and I choose my two points, I am asked what I want to measure (lenght, area, ...) instead of giving me the distance. And if I choose distance, I am asked for two points, and so on.
I'm not aware of having changed any parameter or anything.
Thanks in advance,
Eduardo
PD: here you have a video, in case it may help.
Video
Replies (12)
Message 2 of 13
nestly2
MEASUREGEOM functions require  Dynamic Input to be enabled  (F12)
Alternately, you could use DIST command.
Message 3 of 13
Thank you very much! I'll accept it as solution in a minute.
By the way, in the past only the number was shown (the menu and the grey rectangle weren't). Do you know how to change that back?
Smiley Very Happy
Message 4 of 13
nestly2
DYNPROMPT = 0
Message 5 of 13
Thankyou, this has been driving me crazy since I switched to Autocad 2017! Now if I could just figure out why changing colours is taking so long, I'd be as happy with this as I was with previous releases!!
Have some Kudos!!
Message 6 of 13
Thank you for your answer but i still have same problem, is there anything else need to be active   or inactive in order measure to work?
Message 7 of 13
neaton
DYNPROMPT set to 0 will get rid of the gray box and command prompts will be on the command line. If Dyn Input is on the distances show on the object; if it is off then they are on the command line.
Nancy
Message 8 of 13
WHAT IF I GET THIS KIND OF MEASURE? ALL I WANT IS THE SIMPLE MEASURE IN MM BETWEEN 2 POINTS. TKS
Message 9 of 13
neaton
Is the drawings set to millimeters in DWGUNITS? If you select the element and look at it's properties (CTL-1 to turn on Properties palette) what is the length? It appears the item is very long to measure 2 +99 so it may not be on a flat 2D plane but have end points at different elevations. Can you attach the drawing for us to look at?
Nancy
Message 10 of 13
answering your question, yes, the units are in mm
maybe this is the real problem...things are not on the same plan. I've tried to fix this with a routine that i got in here but all of sudden all other things are going wrong. Now I can't exe fillet, trim, rectangle doesn't have the anchor dots on corners...really i don't know what do do.
If anyone can help please do it on the next 2 hours ...on the 3th i may kill myself...ahahaha
attaching file and it happened to others files as well...
thanks for answering me
Eliana
Message 11 of 13
neaton
The horizontal and vertical blue lines on PADERES layer are the only ones at the extreme elevation. I did a zoom extents then selected everything and changed their Z elevations to 0.0 in the Properties Palette. This fixed the issue but doesn't solve why it was happening to begin with since ELEVATION is set to 0. AUDIT did find a few errors so one of those may have started it. Do an audit on your other files then manually change everything to elevation 0.0 (takes less than a minute using the Properties palette). I didn't see the extreme elevations inside any of the blocks although not everything is at elevation 0.
Anyone else have any ideas?
Message 12 of 13
this layer paredes is the one that came from the constructor file.
I tried before to set zero on z's but blocks wont allow me to do that, i have to explode them all.
rectangles so far follow the blocks , can't pit them on z=0,00
but its a start.
thanks
Message 13 of 13
neaton
You don't need to explode the blocks to change the elevations. Open the blocks with the Block Editor (BEDIT or select the block, right-click and choose Block Editor in the right-click menu) and move the linework to elevation 0 in the Properties palette and save the blocks.
