Since days ago I have problems to open Autocad 2017, run the application and it does nothing. It is the open process without consuming almost memory and doesn't do anything else. Is it possible it is for any Windows Update? this problem has happened to someone?. I have updated drivers, disable the firewall, run as administrator, run as another user, disable the antivirus and do not have achieved anything. In the Windows Viewer there is no application error.
Thanks.
Yes, it could be a Windows Update....could be. Was it ever running right? If so, check for a Restore point to run that is back in time when it was working. Run it and see if that gets you going again.
Did it ever run correctly?
What are your system specs?
It has been running for two months on this computer without problems and the only change that occurs to me is some update...
