Problem with Zomm to All
amarkonathala
amarkonathala
Hi All
My Drawing is not properly Zoom to All, I deleted all the elements which are outside the layout but Y is not fit to screen I dont Know,
Please help me out with this issue
Thank You....
Kent1Cooper
Zoom All takes in not only drawn objects, but also the drawing limits, which by default have their lower left corner at 0,0.  [In Imperial units the default upper right corner of the limits is 12,9 -- I'm not sure about Metric units, but you can find out by typing LIMITS.]
Try Zoom Extents instead.
Kent Cooper, AIA
amarkonathala
while iam double clicking it doesn't come to zoom its showing like that
Kent1Cooper
I can only assume there's something you missed in deleting.  Make sure all Layers are Thawed and On, and REGENerate.  ERASE, type ALL, then the Remove option and use a Crossing window to select the parts you want to keep, to Remove them from the selection.  That should get rid of whatever tiny far-out thing(s) you have, unless it's part of something you kept, such as a far-away Point that's part of one of your Blocks.
Kent Cooper, AIA
pendean
Community Legend
Community Legend
Share your DWG file here with us please.
