Problem with Tiff images from Pix4D
aplitop
Message 1 of 11
aplitop
Hi, I am trying to insert a TIFF image generated by Pix4D application, but AutoCAD does not recognize the format. This image has LZW compression, and a size of about 3GB. Need to know what the limitations of AutoCAD with this type of TIFF, because I've tried to recompress the file using JPEG compression, with more or less compression factor but stays locked AutoCAD.
Replies (10)
Message 2 of 11
Pointdump
Hi Elena,
Details please on how you are importing the Tiff. Are you importing it with the Raster Tools IINSERT?
There used to be a 2GB limit on Tiff Import, but I don't know if that still applies. You can crop a big Tiff with the free >>>GeoViewer<<< to see if that works.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 3 of 11
aplitop
Hello, from what it seems the problem is not only in the size of the image, but in the encoding, since although they are TIFF images, both AutoCAD and the GeoViewer application do not recognize this format, and do not allow cropping or do anything with those images. Can you tell me what kind of TIFF is not supported by AutoCAD?
Message 4 of 11
Pointdump
Elena,
"...what kind of TIFF is not supported by AutoCAD?"
I guess the kind you have? How are you trying to import the image into AutoCAD? What version or vertical of AutoCAD do you have?
Drag-n-Drop that image into QGIS. If QGIS can't open it, you've got problems. You might also try re-saving in IrfanView.
As a last ditch effort, please post your image with Autodesk Drive or DropBox.
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 11
S.Faris
Refer to this : http://help.autodesk.com/view/ACDLT/2019/ENU/?guid=GUID-E694F465-08C4-47B7-9A68-CC6B532F566E
Note: AutoCAD 2000, AutoCAD LT 2000, and later releases do not support LZW-compressed TIFF files, with the exception of English language versions sold in the US and Canada. If you have TIFF files that were created using LZW compression and want to insert them into a drawing, you must resave the TIFF files with LZW compression disabled.
SALMANUL FARIS
Message 6 of 11
aplitop
Hello, I am using version 2022 of AutoCAD, and the image can be imported in QGIS. In AutoCAD I use the Insert> Raster Image Reference option and it shows the error message that you can see in the following image. I also attach a link to the original image with LZW compression and 3GB size. I have tried to recompress the image with JPEG compression to 50% and it stays at about 600Mb, it seems that this way it does not give the error message and it asks you for the position and the insertion scale in the drawing, but it takes A lot time, in fact I have not gotten to see it inserted, because I have cancelled the task of how long time it was taking. This last image I have also tried to read with GeoViewer, but it says that it does not recognize the format, QGIS does import it without problems. I also attach a link to this image, in case you can tell me something about it. Thank you very much and regards
[cid:image001.png@01D7725A.E09F5340]
Link for download images: https://aplitop.sharefile.com/d-s01360382c851485d89fddaecc899ef22
TRAMO1_transparent_mosaic_group1_TILED1.tif Compress JPEG size 600MB
TRAMO1_transparent_mosaic_group1.tif compress LZW size 3GB
Message 7 of 11
Pointdump
Elena,
Thanks for posting your Tiff.
GeoViewer takes about 5 minutes to load that monster. I hugely dropped the resolution and re-saved. The resulting file was only 3.65MB, but even though it loaded quickly in AutoCAD it was unusable because of the poor resolution. So I'd recommend breaking up the full-sized file into Hi-rez pieces in Geoviewer. This little piece, at Hi-rez, is 1.3GB, but it plops easily into AutoCAD.
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 11
aplitop
Hello, how do you get to load the image in GoeViewer? I do it as shown in the image, File> Add Layer> Local layer and I select the Tiff file and it returns the error of the following image. I'm waiting for your answer, regards
[cid:image001.png@01D77283.D0286730]
[cid:image004.jpg@01D77284.0CCB2B50]
Message 9 of 11
Pointdump
Same as you, in GeoViewer I use File >> Add Local Layer.
Your Screen Shots of the Error don't show up. I don't see anything.
Dave
Dave Stoll
Las Vegas, Nevada
Message 10 of 11
aplitop
I had added the image in the body of the message, anyway the message says the following:
Error Opening Layer
Couldn`t open local layer:
file name
The provided path format is not supported
Is it because the version of GeoViewer that I have is missing any codec? Thanks and regards
Message 11 of 11
Pointdump
Here's my version of GeoViewer:
Dave Stoll
Las Vegas, Nevada
