Problem with select object area on Autocad 2016
Hi everyone.
I has changed to use 2016 version from 2011 ver but it has somes inconveniences to me.
When i press and drag mouse to select object, the select window is not quadrilateral shape as 2011 ver, intead it is seen like base on polar coordinates.
Do you have a solution to fix it ?
Thanks.
ennujozlagam
PICKAUTO change value (default is 5)
