Problem with reflections at rendering process
Hello
I am having some difficulties during the render process. As you can see from the attached file, there are some "reflections" and I don't know why is that happening and what's the solution. This image is rendered to size 3300 x 2550 px(11x8.5 in 300 dpi).
Thank you in advance
sophia_lee
Hi @Anonymous ,
Please try one or more solutions below and see the forum site >>here<< for your further reference.
  • Change the value of FACETRES. for example set to 10.
  • Reduce the quality of the render from High to Draft and compare.
  • Add some more lights in the room.
Hope this helps. please accept as solution if this answers your question .thank you,
Sophia, Lee
Sr Technical Support Specialist
Customer Technical Success APAC
peterm
It could be reflection off the glasses.
Take them out and see if the results are any different.
