Problem with open files with autocad
marco.defina
marco.defina
i have installed the Collection so i have many Autocad (MEP, P&I, Architectural,...).
I will open default with Autocad normal. Everytime i click on a dwg and open with P&I. How can i resolve?
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
imadHabash
I suggest to right click on a dwg file then go to Proprieties(see attached image),
Good Luck..
Imad Habash
marco.defina
I've done it! But doen't work everytime with P&ID...
pendean
Community Legend
Community Legend
Start the program you want, then open your file: never fails.
Or grab a "send to" WIndows tool to add to your PC, then right-click and "send to" whatever app you want. Relies on last use profile in the app, so this may not be a good fix.
