Problem with move, strecht, extrude command
Message 1 of 12
Hi everyone,
I have bought a new computer, and installed autocad 2019. I'm having big issues with all the commands involving a move. basically it looks like the items are attracted by an other point in the drawing, so I can't move them properly or strecth etc.... I have attached a video of the screen. I also installed 2021 version, and I 'm having the same issue.
Replies (11)
Message 2 of 12
imadHabash
Q: does this happened if you start a new empty CAD dwg and just MOVE and STRETCH a line ?
if it's OK ... please attache here your CAD dwg ( with the problem ) for testing ?
Imad Habash
Message 3 of 12
It does it with any file,  even with a new drawing. I join you a little video of what it does just after 2 minutes I'm working in the new drawing.
It doesn't do it all the time, so this lead me to believe it is a bug from windows more then autocad.
Message 4 of 12
parkr4st
turn off all  snaps to eliminate the possibility that is causing the problem.  grid, object, etc.  the snaps are on in your settings.
Message 5 of 12
imadHabash
would you try this please :
  • try another mouse , any changes ?
  • dock your command line ( not floating ) .
Imad Habash
Message 6 of 12
Thanks for your help but it still not working. have a look at the video.
Message 7 of 12
imadHabash
i notice from your previous attachments that your Hardware acceleration icon is turning OFF/on automatically !!!
is that real ... ? you may need to check your drivers ?
Imad Habash
Message 8 of 12
I have changed the mouse and it is not longer causing problem. I will work a bit with it then I will accept the sollution if I see this was the issue
Message 9 of 12
imadHabash
Great ... waiting for confirming the issue .
All the best ...
Imad Habash
Message 10 of 12
Alfred.NESWADBA
can you please type in the command as shown here:
_.MOVE<ENTER>
...are you now asked for objects and than for basepoint?
You might have a tool which overrides the _MOVE command (or the M shortcut, if defined?).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 11 of 12
I m not sure but my Nvidia graphic driver is up to date. Is it an other driver involved with the hardware accelarator?
Message 12 of 12
I had this problem with all the command with a deplacment, move stretch
extrude.
Now I have changed the mouse and it looks like it is working again. Many
thanks for your help
