Problem with font
Problem with font
theo_ogeUZATQ
Problem with font
theo_ogeUZATQ
Community Visitor
Community Visitor
Hi, I have a problem with fonts. When I open my autocad file the font changes automatically and that's a problem because everything shifts and it's not suitable. Do you have a solution ? Thanks
vinodkl
Hello @theo_ogeUZATQ
You are seeing this issue because the required font is not found and it is being replaced with another font. Please ask the drawing provider for the required font or ask to ETRASMIT the drawing so that the fonts are included along with the drawing. Use the command FONTALT and type in "." for no alternate font to be used when specified font is not found. Doing so, you will see a popup when opening the drawing to locate the missing font 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
