Problem with creating a curve line with precise coordinates
assen_pandov
Message 1 of 24
assen_pandov
I'm trying to create a curve line 61cm with exact coordinate points...  I need precise coordinate on each 16,5mm.
If I use the spline the line doesn't pass on the exact coordinates even if I give tolerance 0.0000.
When I convert it to poly line and  put high precision the CNC struggles to do smooth curve..
If I do it directly with poly line and after that give a "curve fit" should it be better?
Those are the coordinates I need:
0,5.884
0,29.603
7.5,5.504
7.5,29.944
24,4.723
24,30.626
40.5,4.108
40.5,31.235
57,3.502
57,31.800
73.5,2.899
73.5,32.325
90,2.422
90,32.784
106.5,1.991
106.5,33.193
123,1.558
123,33.575
139.5,1.212
139.5,33.892
156,0.944
156,34.139
172.5,0.695
172.5,34.373
189,0.484
189,34.568
205.5,0.326
205.5,34.705
222,0.185
222,34.837
238.5,0.073
238.5,34.941
255,-0.006
255,35.006
271.5,-0.064
271.5,35.059
288,-0.098
288,35.091
304.5,-0.110
304.5,35.102
321,-0.098
321,35.091
337.5,-0.064
337.5,35.059
354,-0.006
354,35.006
370.5,0.082
370.5,34.914
387,0.200
387,34.802
403.5,0.351
403.5,34.660
420,0.536
420,34.469
436.5,0.775
436.5,34.256
453,1.058
453,34.003
469.5,1.375
469.5,33.675
486,1.781
486,33.306
502.5,2.292
502.5,32.850
519,2.780
519,32.331
535.5,3.377
535.5,31.765
552,4.105
552,31.115
568.5,4.777
568.5,30.402
585,5.555
585,29.635
601.5,6.500
601.5,28.791
609,6.935
609,28.374
Can someone suggest me the best way to do it simple, smooth and accurate ?
Thanks in advance
Replies (23)
Message 21 of 24
Kent1Cooper
@assen_pandov wrote:
If I change "arc and smoothness circle" to "1" is really off, if I put it to 20000 it's closer.. should I leave it to 20000?
Yes.  Lower values made a difference in speed back when computer processors were much slower, but with today's processors you may as well leave it at the maximum value.
Kent Cooper, AIA
Message 22 of 24
assen_pandov
will do! Thanks!
I don't know with the older versions, but when I gave the file to the cnc guy, he wanted me to safe it on older version of the Autocad..
Message 23 of 24
leeminardi
From the data in the first column of your original post I created three curves.
- polyline (red)
- degree 3 spline (green)
- degree 2 spline
I also added point objects at each data point.
If you zoom in very tightly to one of the data points (I choose the 18th) you would see the following.
The precise location of data point 18 is the red point (and white "X").  If you select either of the splines it's fit point  grip #18 will show to be at the data point although the spline itself does not appear to pass through it.  The difference could be due to a display issue or the precision of the math used to determine CV location from fit points (not a simple calculation).  The green point is the result of adding a point on the green spline using object snap nearest.  Obviously it should be exactly on the spline,  The white point is the nearest point when clicking on the white spline. I believe there are some approximations being made for speed of display and that may be the cause of the apparent error.
If the red polyline is not smooth enough for your application when you use it to machine a part I suggest using either a 2nd or 3rd degree spline.  If you post process cannot handle B-splines then I would use splinedit with a precision of 10 to convert the spline to a polyline that will have more chords and hence will produce a smother machined profile.
lee.minardi
Message 24 of 24
assen_pandov
Thanks, will try! Just when i put precision to 10 there are too many points and machine sometimes stops and make small wholes on the metal..  i try to keep as less points as possible to make it work..
