Problem with creating a curve line with precise coordinates
assen_pandov
Message 1 of 24
assen_pandov
I'm trying to create a curve line 61cm with exact coordinate points...  I need precise coordinate on each 16,5mm.
If I use the spline the line doesn't pass on the exact coordinates even if I give tolerance 0.0000.
When I convert it to poly line and  put high precision the CNC struggles to do smooth curve..
If I do it directly with poly line and after that give a "curve fit" should it be better?
Those are the coordinates I need:
0,5.884
0,29.603
7.5,5.504
7.5,29.944
24,4.723
24,30.626
40.5,4.108
40.5,31.235
57,3.502
57,31.800
73.5,2.899
73.5,32.325
90,2.422
90,32.784
106.5,1.991
106.5,33.193
123,1.558
123,33.575
139.5,1.212
139.5,33.892
156,0.944
156,34.139
172.5,0.695
172.5,34.373
189,0.484
189,34.568
205.5,0.326
205.5,34.705
222,0.185
222,34.837
238.5,0.073
238.5,34.941
255,-0.006
255,35.006
271.5,-0.064
271.5,35.059
288,-0.098
288,35.091
304.5,-0.110
304.5,35.102
321,-0.098
321,35.091
337.5,-0.064
337.5,35.059
354,-0.006
354,35.006
370.5,0.082
370.5,34.914
387,0.200
387,34.802
403.5,0.351
403.5,34.660
420,0.536
420,34.469
436.5,0.775
436.5,34.256
453,1.058
453,34.003
469.5,1.375
469.5,33.675
486,1.781
486,33.306
502.5,2.292
502.5,32.850
519,2.780
519,32.331
535.5,3.377
535.5,31.765
552,4.105
552,31.115
568.5,4.777
568.5,30.402
585,5.555
585,29.635
601.5,6.500
601.5,28.791
609,6.935
609,28.374
Can someone suggest me the best way to do it simple, smooth and accurate ?
Thanks in advance
Replies (23)
Message 2 of 24
Kent1Cooper
@assen_pandov wrote:
.... If I use the spline the line doesn't pass on the exact coordinates even if I give tolerance 0.0000. ....
It does for me:
I put your coordinates into a file that I called junk.txt, in a place where AutoCAD knows to look.  They came in one XY pair per line [I had to remove blank lines between coordinate-value lines], so the file is like this:
0,5.884
0,29.603
7.5,5.504
7.5,29.944
[I hope that's the right sequence, and not straight down your left column and then up the right, or something].  Then:
(setq file (open (findfile "junk.txt") "r"))
Command: SPLINE
Current settings: Method=Fit Knots=Chord
Specify first point or [Method/Knots/Object]: (while (setq pt (read-line file)) (command pt))
and ended with Enter to conclude the Spline command, and (close file).
The Spline does pass exactly through those coordinates.  Do you perhaps have the Method option set for Control Vertices rather than Fit Points?
Kent Cooper, AIA
Message 3 of 24
assen_pandov
Sorry i put two curve lines... take just one column..
Message 4 of 24
assen_pandov
for example on coordiante 370.5,0.082 it passes on 0,0868 .. and it's same with almost all the points..
Message 5 of 24
Kent1Cooper
That makes a difference to the result:
but not to the fact that it does go through those exact coordinates, and therefore to the question -- what is the Method option set to in your Spline command, if that's how you're doing it?
Kent Cooper, AIA
Message 6 of 24
assen_pandov
method fit points (I paste all the coordinates and give tolerance 0.0000) but still when you zoom they don't pass on exact coordinates
Message 7 of 24
Kent1Cooper
I tried it by just pasting in the list, rather than with the AutoLisp read-the-file approach, and it also goes exactly through those locations.  I don't have any idea why it would not work for you, unless maybe you're in a UCS other than World Coordinates.  Can you post a drawing file with your results?
Kent Cooper, AIA
Message 8 of 24
Patchy
I couldn't get them to go through the points neither, they are off by a hair of a flea
Your cnc can handle that.
Message 9 of 24
Kent1Cooper
Even in your posted drawing, they do go precisely through those coordinates.  I select the Polyline, hover over a grip until it locks on, and look at the Coordinates display, here at the second vertex from each end:
The coordinates agree down to the full 8 decimal places it can display.  I checked a variety of them [not every one], and all agreed exactly.  Where are you seeing them being off?
Kent Cooper, AIA
Message 10 of 24
Patchy
I see it when I zoomed in really close.
The point goes thru but the spline is off a little bit.
Message 11 of 24
assen_pandov
Sorry was driving, will try to post a file or a picture, but I'm new and I will check how to do it now..
This curve is for a speed skating template..even 0,01-2 makes a difference of the desire result..
Message 12 of 24
Kent1Cooper
Okay, so it's not a question of fit points not being at the right place, which is what I had assumed.  That kind of deviation appears to be the nature of Splines generally, though I'm not sure.
Kent Cooper, AIA
Message 13 of 24
assen_pandov
You did poly line or spline?
Message 14 of 24
assen_pandov
Do you think if I do poly line and put "curve fit" can do the work? or will not be smooth enough?
Message 15 of 24
Kent1Cooper
I did a Spline [see my first Reply].
Kent Cooper, AIA
Message 16 of 24
assen_pandov
I'm sorry for the stupid question, but how can I do my coordinates more precise and I'm using auto cad 2018, should I always safe the file in older version?
Message 17 of 24
assen_pandov
If I change "arc and smoothness circle" to "1" is really off, if I put it to 20000 it's closer.. should I leave it to 20000?
Message 18 of 24
Patchy
Have you actually use the file with cnc yet? many don't read splines, they read arcs and polylines
So does it make any difference where it show on the screen and the coordinate points is what matter.
Message 19 of 24
assen_pandov
Well I tried it on poly line, but it wasn't with the best result, I tried to put it more accurate with coordinate point on each 1,5mm but it was too much and then the CNC was cutting it was stopping on those point and make small wholes in the metal... so I realise that small steps is not working well
Message 20 of 24
Kent1Cooper
.... should I always safe the file in older version?
Does it come out more precisely in older versions?  [The drawing you attached has the same issue when opened in 2019 that I have here.]
Kent Cooper, AIA
