Problem with cmd EDITREF
PC-COMPANY2
Observer Observer
PC-COMPANY2
Observer
Observer
I have a problem with cmd EDITREF. For some block (for exemple called "R+2"), the command works. But sometimes with other blocks (for example called "R+3"), in the same DWG, EDITREF doesn't work. When this happens, I need to do a double-left click to enter in the edition window for this block.
Have you an explanation please ? Cause I found nothing about this particular bug (?).
Thank you, have a nice day and take care yourself.
Stéphane.
Patchy
Never heard of this command, only REFEDIT.
pendean
Community Legend
Community Legend
You using a 3rd party add-on or customization?
REFEDIT is the only command in the core program, see this from HELP https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/AutoC...
patrick.emin
Hi, EDITREF is the French name of the REFEDIT English command.:
@PC-COMPANY2 you could post on the French AutoCAD forum rather since you are using a French AutoCAD.
Patrick Emin animateur de la communauté francophone
Vous avez trouvé un message utile? Alors donnez un "J'aime" à ce message!
Votre question a eu une réponse satisfaisante? Voulez vous avoir l'amabilité de cliquer sur le bouton
 APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Signez notre Livre d'Or
