Problem with AutoCad startup.
I moved the installed file from my program files then there was a problem with the acad startup process starting up. How do i procede to ensure that my acad works?
Alfred.NESWADBA
Hi.
welcome @Anonymous.autodesk.com!
First step: move them back to the original place and hope, that you get it back working.
And NEVER EVER move files within the program folders, this is the fastest way to crash not just the application, but also the complete operating system.
In case you want to have applications moved to a different place you have to uninstall them and then start again the installation (where you can set another installation path).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thanks..
