Problem with Arabic language
Hi ,
I have a problem with Arabic language didn't appear correctly
it's appear as symbols  like this ( ???????)
could anyone help me how can i fix this problem??
oswaldodcb
Hello @Anonymous
I will indicate several links that you can check to correct your problem:
https://forums.autodesk.com/t5/autocad-forum/arabic-font-in-the-autocad/td-p/3411337
https://forums.autodesk.com/t5/autocad-forum/autocad-drawing-converted-to-pdf-arabic-text-getting-change/td-p/6345674
https://www.youtube.com/watch?v=_vRcMNlRDMo
Oswaldo Caballero
Project Engineer / Autodesk Certified Instructor / Autodesk AutoCAD Certified User and Professional
Maracaibo, Venezuela
LinkedIn
Da un Me Gusta si la publicación ha sido de utilidad y si ha resuelto tu duda presiona ACEPTAR SOLUCIÓN
pendean
Community Legend
Community Legend
??? usually means the font needed is missing: ask the person that sent you the DWG file to also send you the font file(s) they used.
