Message 1 of 12
Hi
I have a problem with a file exported from Arcgis. I can open it, zoom in, cut parts, and move around but when i try to process something my Autocad freeze. I had try to audit and purge but it also freeze.
I have tried using other AutoCAD version but still got the same problem. So far have tested in 2010, 2017 & 2018 Autocad Version.
I have cut the large file to a very small portion of the file and still have the same problem.
I'm submitting the sample file, hope someone can help me out to find out what is the problem and how to fix the larger file
My AutoCAD is working fine with all the others files, the problem is particularly with this file.
Best Regards
Jorge
