Problem with 3D shadow resolution
MPLantarón
MPLantarón
Hello:
When I make a basic view of a 3D object from the model, I select shaded with no hidden edges. The problem is that the shading looks very pixelated.
If I select the window, in its properties, it indicates that the resolution of the shadow is 100 PPP. The problem is that I do not see how to upload this resolution since in the properties palette it is "locked".
I think there will be a variable that controls this property, but I can not find it .... does anyone know how to upload the resolution so that the image looks good? (Without having to render or similar things).
Thank you
MPLantarón
I found it!
The _viewstyc command allows you to change the resolution of the view to a maximum of 300ppp.
Bye
