Problem printing
Problem printing
Message 1 of 11
Problem printing
Hi!
I have Autocad 2015.
It have always worked fine printing, but now it stoped working. I cant even open the preview window. I start the printing, select the area but when i press print or preview it does not appear anything. The printing window just disappears.
Is there anybody that recognise this issue?
Best Linn
Replies (10)
Message 2 of 11
vinodkl
Is it that the plot window is not appearing when type in PLOT or press Ctrl+P? Can you share the snapshot for more clarity?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 3 of 11
imadHabash
HI,
if you restart your AutoCAD , any changes ?
Imad Habash
Message 4 of 11
pendean
Community Legend
Community Legend
Message 5 of 11
GrantsPirate
Please clarify - When you are in the plot dialog and you pick preview nothing shows but you are still in the plot dialog?  If you pick print then the dialog goes away and nothing happens?
Is that what you are experiencing?
Let us know what operating system you are using and what plotter driver and version you are using.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 6 of 11
Nope! It have been like this for about a month.. I have restarted the program a lot sice. I just dindn´t have time to fix i until now 🙂 I have sent all my files to my college to print during that time.. (don´t worry, i don´t print every day, so it was just like 2 or 3 files 😉 )
Message 7 of 11
The dialog goes away and nothing happens when i press preview and the same happens when I press print.
My operating system is macOs Catalina version 10.15.2
Message 8 of 11
How do i see plotter driver system?
Message 9 of 11
Now I also noticed that it the command field says "_plot" when the window closes down when press print or preview.. Then it says "Specify opposite corner or [Fence/WPolygon/CPolygon]:" when use the select tool on the drawing.
Maybe I somehow have activated another kind of plot tool that i do not now how it works?
One other thing: In some drawings it automatically choose "Window" in the drop down for "what to print:". In other drawings it choose "Display".. Why? Is that also some kind of selection that i can make that differs from drawing to drawing? When i chose Print from window in the drawing that automatically chooses print from Display, the Print from Window also works differently.
Message 10 of 11
imadHabash
i suggest to reset AutoCAD to default . >> Click <<
Imad Habash
Message 11 of 11
TriedScreenshot 2020-03-19 at 16.23.16.pngScreenshot 2020-03-19 at 16.22.53.pngScreenshot 2020-03-19 at 09.16.50.pngScreenshot 2020-03-19 at 16.34.04.png reseting now.. it does not work anyway 😕
