converting hand-drawn sketched objects to CAD 2D lines and blocks.
cadomatic
cadomatic
hi
couldn't find any other forum here to post this. Sorry in advance.
I am interested in finding an AI software or technology capable of recognizing the vector and location of scanned object, and translate it into 2d CAD objects.
in this example, the handwritten pipes should be translated into CAD 2 lines pipes , and those filled circles into duct blocks.
Shay
Kevin.Spear
HI, I'm not sure what version of AutoCAD you're using. However, there is a markup import tool that does exactly what you're after, mostly. It will create geometry. But you'll have to turn basic geometry into "ducts", etc.
https://www.autodesk.com/blogs/autocad/whats-new-in-autocad-2023-markup-import-and-markup-assist/?re...
Kevin
Kevin Spear, PE
pendean
Community Legend
Community Legend
.... and the free to AutoCAD subscribers RASTER DESIGN add-on can be used if the markup tool above if not quite your need https://www.autodesk.com/products/autocad/included-toolsets/autocad-raster-design
HTH
cadomatic
Thanks for the links.
autocad 2024 wont recognize hebrew text with its markup tool. what options do i have?
RSomppi
Unless your accuracy requirements are very loose, any kind of conversion is going to require verification and rework. The rework can be so involved that it is easier to start from scratch and trace over the image making everything accurate from the get-go.
mhoppe5ZMVM
Observer
Observer
Try this, working with computer vision to make drawings into CAD DFX files, free to start with!
https://www.geopogo.com/sketchtocad
