Problem opening previously saved file autocad 2018
Message 1 of 18
Problem opening previously saved file. After saving a file, with interface in "wireframe2d" mode, when I go to resume the file to open it, the graphic interface changes to "hidden". You can see from the attached photo. how can i solve it?
Replies (17)
Message 2 of 18
j.palmeL29YX
Simply choose the wireframe2d style again (?)
Or did I misunderstand your question?
To avoid a wild guessing around, post the dwg please.
Jürgen Palme
Message 3 of 18
Alfred.NESWADBA
can you please start command _ABOUT and show us a screenshot from this dialog, I guess updates are missing.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 4 of 18
As required I entered the screnshot of the _ABOUT command.
##- Si prega di inserire la vostra risposta sopra di questa linea -##
Message 5 of 18
I inserted a simple file, because the problem occurs with any file I
open. However, if I open from autocad from the OPEN function nothing
happens, if I directly open the file from the desktop or workbook here
is what happens. I also attach screenshots.
Message 6 of 18
Type
shademode
2dwireframe
Message 7 of 18
j.palmeL29YX
Neither Message #4 nor #5 include attachments.
To add attachments, scoll down and click on  "browse".
>>see here<<
Then choose the file(s) to upload.
Jürgen Palme
Message 8 of 18
As required I insert the screenshot of the _ABOUT command.
Message 9 of 18
pendean
Community Legend
Community Legend
Share with us your problem file.
Message 10 of 18
Yes, if I choose the wireframe2d I can continue working, but why when I open the file does not open directly in 2d instead of hidden?
I am attaching a simple file, because so much happens with all the files.
Message 11 of 18
pendean
Community Legend
Community Legend
Are you saving your file after making the changes? And NOT saving back to R2004 file format?
You might have a startup routine doing this for you, no issues here at all with your file, see below and attached.
Message 12 of 18
Alfred.NESWADBA
DWG2004-format does not know visual styles, so when you save a dwg-file back to such an older format (17 years old) it does not contain visual style information. Opening the file then means it starts with the default, and that is "2D Wireframe".
Why do you think it's an advantage to save a file back to that old format?
You'll lose a lot of information doing so.
- alfred -
Alfred NESWADBA
Message 13 of 18
hello, I honestly am not saving in dwg2004, I set by default 2018. If I go into options, Open and save, the saving is set in autocad2018 and not 2004. Should I set in 2004? maybe I didn't understand your concept well.
Message 14 of 18
Alfred.NESWADBA
But the drawing you uploaded (sedia1.dwg) was in DWG-2004 format.
And no, you should not save back. However, for this issue losing the visual style setting and seeing you are using DWG-2004 format, it looks like this is the source of your issue.
Start command _OPTIONS ==> tab "Open and Save" ... which format is set as default?
- alfred -
Alfred NESWADBA
Message 15 of 18
Hi, the problem is also encountered with recent elements that I created myself with the 2018 version, and saved in 2018. When opened directly from files on the desktop or folder and not from softwear they open hidden. I attach a screenshot of the options screenshot.
Message 16 of 18
cadffm
Open  your file, press [F2] and read all information.
SaveAs to dwg2018
Try it again
Sebastian
Message 17 of 18
On the viewport, in the top left corner, click on Visual Style Controls option as indicated in the screen shot and change the option to 2D wireframe.
Message 18 of 18
 What if the problem was setting the file properties.
Let me explain, if I go to the file properties it is set open with "AutoCAD DWG Launcher". this is right?
Because if I set open with "AutoCAD Application" the problem no longer exists.
Now I wonder what difference there is between
'' AutoCAD DWG Launcher '' &
'' AutoCAD Application ''?
