Problem importing fbx. file as a block
Message 1 of 14
I have a problem i can import fbx file as a mesh but when i try to import it as a block the object doesn't show up. I'm using AutoCad 2017. I have added the fbx. file in post Zajeta slika.JPG
Replies (13)
Message 2 of 14
Alfred.NESWADBA
it looks like you are using drag & drop to insert the fbx-file, that does not work.
Instead please start command _IMPORT, in the dialog select *.fbx as filetype, then select your file.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 14
Hello thanks for the reply but i have tried using your method and it still doesn't work.
Message 4 of 14
alex101000
Use Insert, Block, select the name of the imported block.
Message 5 of 14
Alfred.NESWADBA
"does not work" means what?
What did you start, what did you get as response?
I had no issue getting your file imported (find attached)
- alfred -
Alfred NESWADBA
Message 6 of 14
hi, I am still having problems when i try to slice the object it says that it is a mesh.
Message 8 of 14
Alfred.NESWADBA
you have 3 options to answer the dialog you showed in your screenshot, which one have you tried (and which one not)?
- alfred -
Alfred NESWADBA
Message 9 of 14
Hi, i have tried two options new layer and current layer. But saddly none didn't work (I have marked with blue options i have tried).Zajeta slika.PNG
Message 10 of 14
Alfred.NESWADBA
my question was referring to this message:
- alfred -
Alfred NESWADBA
Message 11 of 14
oh sorry i don't know what i was thinking and yes i have tried all 3 but it doesn't work. Everytime I pick one of the options convert selected objects to 3d solids computer just freezes and if i wait and open task manager i can see that computer is doing some work because it uses all the ram and after a few minutes the object just returns to it' original state.
Message 12 of 14
Alfred.NESWADBA
this object has about 250.000 edges, to convert that from a mesh to a solid or to a surface is not a thing of 2 seconds.
What for do you really need that object, what is the final goal?
- alfred -
Alfred NESWADBA
Message 13 of 14
I need object because i want to do some 3d editing on the object and i am making a replica of this chait for my school project and i need to make blueprints in layouts in order to make the project.
Message 14 of 14
Alfred.NESWADBA
I would not see AutoCAD as the best package for editing such a geometry, even other products will have issues as these are not editable geometry parts (like splines based extrusions or something like that).
The preferred method (my opinion) to create a new objects based on that would be to have that object like a background info and to start a new construction (using object snaps, to have a relation to the size).
- alfred -
Alfred NESWADBA
