Printing Existing DWG Drawing to Scale
andyhanson
Message 1 of 14
andyhanson
Hi All,
Apologies for asking this question again as I know it crops up a lot from my searches.  However I have been unable to solve my issue due to a poor understanding of how Autocad uses scale when printing.
I have a site plan produced by a company of our property location which they provided as an A3 printout and also provided us with the DWG file.  The plan was printed onto A3 with a scale of 1:200.  Having loaded the DWG file into Autocad the units appear to be set to metres as when I measure a known building on the plan it is displaying as metres.  I am trying to produce two PDF files of the plan.  The first I want as the company produced it in 1:200 scale on A3 paper.  The second file I want again on A3 but with a scale of 1:1250.  This is for a planning application and they need plans with these scales.
I have been experimenting with the export function and adjusting the scale but have so far failed to produce a scaled print.  Can anyone walk me through the method used to produce the two files I need with the scales I need?
I'm using Autocad on a MAC if that makes a difference.
Many thanks for any guidance.
Replies (13)
Message 2 of 14
leothebuilder
Welcome to this forum.
Printing viewports to scale takes a while to explain......
There are some videos available, here are a few I found doing a Google. There are lots more that explain this.
https://knowledge.autodesk.com/community/screencast/2605e6e3-4d06-4343-9274-8953e305e5a6
https://www.youtube.com/watch?v=45uNMl4rI_o
http://www.cadtutor.net/tutorials/autocad/paper-space-exercise.php
Message 3 of 14
andyhanson
Many thanks for the reply and links.
I've read and watched all those and attempted to replicate what they did.  However whatever I do I can't get the plan to print to an appropriate scale.  I've created a new layout with A3 dimensions in mm (420x297mm).  I then managed to get the drawing onto this layout but when I go to print and select a scale of 1:200 the resultant print has a tiny blob in the bottom left of the printout!  I'm a bit lost at where to go next as I'm obviously doing something fundamentally wrong.
Message 4 of 14
Patchy
Attach your drawing and get it done faster.
Message 5 of 14
andyhanson
OK I've attached the drawing.  I really wanted to work this out myself so am keen to learn where I've being going wrong.
Message 6 of 14
leothebuilder
If you have a viewport layout in "paper space" already properly scaled at say 1:100 you should not in the plot dialog box set this to print at 1:200 scale.
You should print "per space" or layout to scale 1:1. (the viewport determies the scale, not the plot)
Message 7 of 14
leothebuilder
First you need to set your units correctly.
Enter DDUNITS on the command line and set what you want to use.
You have a decimal drawing that uses inches.
Set your units to millimeters or meters. Architectural plans usually millimeters in Europe correct?
Then I would place your title block in layout space and create a viewport to whatever scale you want to display this site plan.
Message 8 of 14
leothebuilder
P.s. I just figured you were using meters as units which surveyors noramally use.
Message 9 of 14
leothebuilder
Here's the file with the title block inserted using meters and viewport at scale 1:200
You don't get the whole drawing onto that sheet size, you may have to increse scale to 1:400 or 1:500
Message 10 of 14
andyhanson
Yes correct, the plan is in metres.  So if I create a new layout with units in mm and draw a rectangle A3 size (420x297mm) will this work or do I have to stay with metres as the original plan is in metres?
Message 11 of 14
leothebuilder
You can stay with meters, you just have to set your sheet at 0.42 x 0.297 (meters) rather than 420 x 297 mm.
If you want to use millimeters, you would have to scale your drawing in model space x 1000 (1 meter = 1000 mm) and than you
can use a tile block that is 420 a 297
If you are using metric, you should use metric linetypes. It looks like you;re using imperial linetypes.
Start with a metric template is best,
Message 12 of 14
Patchy
Try this and see:
Message 13 of 14
andyhanson
Thanks for all the replies and your time on this.
As I mentioned this is a plan drawn up by an external company and they supplied the DWG file.  I've no idea why they've done it the way they have.  I had assumed they had printed the paper plan they also provided using the DWG file they sent.  The paper plan we have is on A3 and contains the entire site all scaled to 1:200.  They also produced a second plan scaled to 1:500.  Again they provided a DWG file of this scale as well.
It would appear from what you're all saying and demonstrating that it isn't possible to print the entire map onto A3 at a scale of 1:200?  I therefore don't understand how they managed to print it to scale on A3.  I'm confused, which is easily done!
Edit:
Just double checked and I'm incorrect - sorry.  The 1:200 scale map is printed on A1 not A3.  The 1:500 is printed on A3!  So I'll go back to the drawing board now and try doing it at A1 size.
Message 14 of 14
Patchy
A quick calculation would tell you it's impossible.
the Vertical grid = 100 m = 100.000mm    scale 1:200  would need  500mm of paper of horz. length
Then A3 is not enough.
