AutoCAD Forum
Printing Area boundary line
4 REPLIES 4
2959 Views, 4 Replies
Hi to all you professionals out there I have an exercise file that was downloaded to go with a tutorial and in one particlur file there is a drawing in the Model space obviously, along with a named layout tab and Viewport - then in it or on it (the Layout tab) it has the dotted printable area around the Viewport but when I open another Layout tab the Printable dotted line does not appear and nor does it in subsequent layout tabs I open...
In the OPtions Plotting setup page the printable area is checked I unchecked and re-check it but still no printable area on new layout tabs. I am baffled that it is visible in in one Layout Tab, the one next to the Model-space tab, but not any new ones I open...Any suggestions would be greatly appreciated.
Cad Learner
4 REPLIES 4
Alfred.NESWADBA
This depends on the device and the paper-format activated for that layout.
Start command _PAGESETUP for each layout and verify both settings.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Hi thank you for your help Alfred but Alas it didn't work...I have noticed on Youtube tutorials every time they open a new Layout tab in AutoCad by default, the Printable dotted area border line around the sheet appears automatically....I didn't think you had to 'opt in' so to spaeak to see the dashed printing area....Imay be wrong
What do you think Alfred?
Thanks in advance
Cad-learner
Alfred.NESWADBA
That depends on the settings of the default device you have configured.
But the question is not the same you asked, in your first message you wrote "change to another layout" ... which means another layout already existed and had already set it's page-setup.
Anyway, I never think about my default settings when I "create a new layout". In most cases I use an existing layout and duplicate it (or import it from another drawing).
If I really have to create a new layout from scratch I start immediately into the page-setup and set the device and paper-format. So I also get always the same printable area displayed.
HTH, - alfred -
Alfred NESWADBA
Thank you Alfred I should stop and think a bit more about the problem before I post it...
Thanks again for you expertise on this issue.
Cad-learner
AutoCAD Inside the Factory
