Printer Issue - Partially Printed Text
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I recently upgraded to AutoCAD 2020 from 2019, and it changed my printer settings. My OS is Windows 10, and I'm using the same printer (HP 7612) and sheet size (tabloid small margin). The print area is now positioned differently, so it caused prints to run off the edge, and some of the text was only half printed (some letters missing). I resized my titleblock for the new printable area, so that's fixed, but it's still only partially printing printing the text. In the examples I'm attaching, Preview.jpg shows what it should print, and Print.jpg is what actually printed. On this example it's only the text in the lower left corner (the box around it had no problem). It seems to arbitrarily choose what not to print. Sometimes it's dimension text; sometimes it's MText, and sometimes it's regular text. All of this text is in model space, and I am printing from paper space. All of the text is on a printable layer (wouldn't show up in the preview otherwise). My titleblock is in paper space, and it doesn't seem to be having issues printing text yet.
Another similar text issue on another drawing: I have several Qleaders on the drawing; they all have a text frame on, set through properties. Some of them print with just the frame and leader, and some print text, frame, and leader. If I delete one not printing and copy one that is, it works, but they were all copied from the same initial leader in the beginning! I didn't have this problem a couple weeks ago when I was using 2019.
I do currently have a less convenient workaround, so I'm not out, just down. The workaround involves more steps, is more time consuming, and doesn't result in the same quality of print. I can print to pdf and print the pdf on the printer just fine, but the lines aren't as bold. If anyone has any ideas, please let me know what you got.
