PRINTER CUSTOM PAPER SIZE
dm0144
dm0144
Hello everyone
Any idea why I am not able to add custom paper size for my printer device?
Currently, I am trying on two printer devices, and on both of them I am not able to add custom paper size in order to print directly form AC with out having to first plot the paper size as a PDF.
vinodkl
Hi @dm0144
Check this article on how to add custom paper size 🙂
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/unable...
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
tboehler
click on Custom Properties in the same dialog box (up 2 lines).
Then you can create custom page sizes.
Michiel.Valcke
For Printing Hardware, not all Printing Drivers will allow external programs such as AutoCAD to change their settings. (such as adding custom paper sizes) You will need to open the Printer software and add the custom paper size there. Once you have succesfully done so, AutoCAD should recognize the paper size, and list it as one of the possible sizes for printing.
