generate upper surface
bhbloom
bhbloom
Community Visitor
Community Visitor
I need to design a 'fill in' piece with a flat bottom and different heights at each corner so the upper face slopes. ideally I would like to specify  each corner height to generate the upper surface.
beyoungjr
Can I offer the following tip to get you working toward a solution...
Draw 3 lines in model space using 3D coordinates;
Example
  1. Line-> 0,0,0 first point, 0,0,2 second point
  2. Line-> 6,0,0 first point, 6,0,3 second point
  3. Line-> 6,2,0 first point, 6,2,3 second point
  4. Line-> 0,2,0 first point, 0,2,2 second point
Now use the Viewcube to change you perspective and notice the endpoints of the vertical lines.  You can simply create a surface using those endpoint.  The surface will have a tilt toward the left end of the frame that was  represented by the 4 vertical lines.  A surface generated on the bottom endpoints would be flat.
This is a very simplistic process of generating a tilted surface.  Many other techniques are available but hopefully this will get you started and visualizing a basic method.
Cheers,
Blaine
Blaine Young
Senior Engineering Technician, US Army
