Print with hidden lines
tmccar
tmccar
I have a PS viewport which shows an isometric view in hidden line mode. But when I print to pdf, it switches to wireframe.
How can I  print in hidden line mode?
Replies (8)
cadffm
Sorry.
Sebastian
imadHabash
>> But when I print to pdf, it switches to wireframe. <<
is there any page setup that you use ? if not , check your VP's visual style . also you can select your VP then Ctrl+1 and change your Shade Plot from Misc tab .
Imad Habash
peterm
Make sure Shade plot is set to "As displayed".
tmccar
Shade Plot is greyed out, so I can't access it.
peterm
Can you post a drawing that has this problem?
tmccar
Ok, it's posted
peterm
I'm not sure why that option is greyed out on the plot dialog, but I had no problem setting the viewport to hidden line and then plotting (see attached pdf).
sdg289
- Right click Properties to open Properties Palette.
 -Select the viewport, and change the "shade plot" to legacy hidden on the Properties Palette.
