Solved by oswaldodcb. Go to Solution.
Hello @Anonymous
I attach some links to you to see the procedure to follow:
http://www.cad-notes.com/5-steps-preparing-your-autocad-plot/
https://www.youtube.com/watch?v=Qoe9yax2Y9E
If you have any doubts, I can gladly assist you,
Oswaldo Caballero
Project Engineer / Autodesk Certified Instructor / Autodesk AutoCAD Certified User and Professional
Maracaibo, Venezuela
LinkedIn
Da un Me Gusta si la publicación ha sido de utilidad y si ha resuelto tu duda presiona ACEPTAR SOLUCIÓN
>> ....wanting a drawing that is 35 mm in length to print (pdf) at 35 mm in length.<<
you have to prepare your plot settings in proper way that fit your needs.paper size and plot scale MUST be selected in correct way with your elements.
Imad Habash
A pleasure to be able to help you @Anonymous,
Any other questions you may have, please let me know,
Oswaldo Caballero
LinkedIn
Oswald, your links provided in depth solutions. Great help, easy to understand. Thank you so much!
i agree with you ... we all here for providing good and warm help to others.
glad that your issue is done
Imad Habash
