Primary dimension text alignment is changing when dual display dimension is enabled
I am facing an issue , after setting dual dimension on, primary text is automatically formatted to center.
  • I enabled dual unit and selected alternate dimension below to primary in the dime style Text alignment with dual display offText alignment with dual display offText alignment with dual display onText alignment with dual display on
  • Observed the primary text alignment is automatically moved to center.
  • PFA for both the files
Can anyone help me out by explaining why primary unit are aligned to center.
Thanks in advance.
Edited
imadHabash
as much as i understand ... your Text placement is assign to Center , also you can change your Alternate units placement from Alternates Units >> Text placement .
Imad Habash
