prevent additive transparency
jdfnnl
jdfnnl
The goal is to juxtapose new with existing by fading the existing elements. Is there a way to accomplish this without the additive effect of overlapping transparent lines?
pendean
Community Legend
Community Legend
Would one of those files be an XREF? or could be if you want to do what you want, and XREFs have a fade option in OPTIONS even in your AutoCAD2015 version I believe.
Or you could play with screen colors, select ones that look faded on your screen. and combine(or use) a PLOT STYLE TABLE settings for that as a plotted effect too.
jdfnnl
It does seem like using CTB file plot style with screening option would solve this, but I would need to redefine a number of new colors, one additional for each line weight I am using, then assign the desired screening, possibly 40 out of 100 to match the 60% transparency as seen in the screenshot.
@pendean I believe the fade on xrefs does not print
I think screening is the alternative to transparency that is not additive. It would be great to know other ways of applying the screening effect, as what I mentioned above would be a lot to manage. I have not worked with STB plot styles yet, but maybe this provides a way of creating pairs layers (one for new and one for existing) with matching colors, maybe also with transparency that displays but doesn't print?
pendean
Community Legend
Community Legend
Indeed, that's why I presented two answers since your need seemed unclear to me: a display-only solution, and a print-solution (CTB or STB, which can also be a display solution if you turn on the display option in that pagesetup).
