Practice test question: What does the DRAWORDER command allow you to do in the drawing? (Select three.)
ym.56789
ym.56789
I'm studying for certification, and here is a question from the practice test Autocad provides (available here):
Select 3 answers below.
( ) Send All Annotations to Back
( ) Bring Leaders to Front
( ) Bring Hatches to Front
( ) Bring Dimensions to Front
( ) Bring Text to Front
Explanation: The answer can be found in Organize Objects
Well, I can't seem to get the correct answer. I tried with Autocad LT 2023, and the last four options are all true. I can bring; leaders (MLeaders, Leaders and Qleaders),  text (TEXT or MTEXT), hatches and dimensions - all to the front using the DRAWORDER command from the context menu. I can't choose four options though, only three. And I can't seem to figure out which three I'm supposed to guess.
Any help would be appreciated.
Accepted solutions (3)
imadHabash
 DRAWORDER command bring all text, dimensions, or leaders in a drawing in front of other objects .
Imad Habash
ВeekeeCZ
( ) Send All Annotations to Back  Front
( ) Bring Hatches to Front Back
cadffm
If the title/topic is "What does the DRAWORDER command"
ALL answers are wrong! or all answers are right!
The draworder command don't have options for any object type,
the command is asking for your object selection and there is no
filter - you can select what you want and draworder works with all objects.
(perhaps some trouble with images and other "underlays", but this is another problem)
If the title/topic would be "What does the TEXTTOFRONT command" ( ) Send All Annotations to Back
(X) Bring Leaders to Front (for leader lines ONLY = stupid², and mleaders)
(X) Bring Dimensions to Front
(X) Bring Text to Front (Text and MTExt)
If the title/topic would be "What does the HATCHTOBACK command" ( ) Send All Annotations to Back
( ) Bring Leaders to Front (for leader lines ONLY = stupid², and mleaders)
( ) Bring Text to Front (Text and MTExt)
Sebastian
