Postscript (.eps) plotter not showing
Somin.Agrawal_KBQZWMY4S7Z2
Observer Observer
Observer
Observer
Hi, I am facing an issue while adding a Postscript Level 2 'plotter' in Autocad. In the past, I have used it to plot drawings (plot to file - option) in '.eps' format. But now I am on a new system and after successfully installing a Adobe Postscript Level 2 plotter via 'add a plotter wizard', the plotter is not showing up in the drop-down menu of the plotter list while plotting. I have tried restarting AutoCad and even my system, but the plotter is not showing up even after multiple attempts. Any help is greatly appreciated. Thanks in advance!
pendean
Community Legend
Community Legend
"not showing up" can also mean it never got created. Go to that folder using PLOTTERMANAGER command and find out for sure.
Observer
Observer
Hey thanks for taking the time out to reply!
I am sure the plotter is added because I have tried installing it multiple times and each time at the final step it says "The file already exists" and I ahev to rename the plotter name to something else. But none of those show up in the drop-down list.
Observer
Observer
pendean
Community Legend
Community Legend
@Somin.Agrawal_KBQZWMY4S7Z2 Go to that folder using PLOTTERMANAGER command and find out for sure, then delete it, start over again.
