Positioning the Command Line Window below the Layout Tabs in 2016
dennis
Advisor Advisor
Message 1 of 13
dennis
Is there a way to dock the command line below the layout tabs in AutoCAD 2016?
Replies (12)
Message 2 of 13
Patchy
Maybe it's locked and you can't move it.
Use LOCKUI command and unlock it or hold down the CTRL key and move it.
Message 3 of 13
dennis
Thats not it.  I can freely move it and dock it.  I just can't get it positioned below the layout tabs as well as docked at the same time.
Message 4 of 13
nrz13
Now that the layout tabs have been merged with the statusbar in 2015 & 2016, I don't think this is possible.  Layout tabs are no longer on a per-window basis but always down in the new statusbar.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 64GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Message 5 of 13
GrantsPirate
An option is to stretch the window up, undock the command line and place it below as a floating palette.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 6 of 13
dennis
GrantsPirate:  yep, that is my work around...not very elegant, but works.
Message 7 of 13
This changed with 2015 (possibly 2014, but I skipped 2014 so I'm not sure) and I was told in an email from Autodesk that they cannot be moved. As mentioned, they are now merged with the status bar and are stuck on the bottom. I agree that it would have been nice if there was an option to have them above or below the command line because sticking them in line with the status bar icons drastically limits how many tabs you can have before they start hiding.
By the way, you can at least dock the tabs above the status bar as opposed to in line with them by right clicking on a layout tab and selecting "Dock Above Status Bar". If you are having problems with the status bar icons hiding tabs, this helps quite a bit. But they are still stuck below the command line.
Message 8 of 13
I have to say I am pretty pissed off about this issue.
The problem is two-fold for me...
In order to make the screen STOP FLICKERING when zooming I have to do this:
"dock above status bar" the layout tabs
( https://forums.autodesk.com/t5/autocad-2013-2014-2015-2016-2017/autocad-2016-screen-flashing/td-p/56... )
which creates a "huge" unusable chunk of real estate below the layout tabs AND above the status on the right side of the screen.
And dont tell me its a graphics card issue. NVIDIA Quadro K5200 installed.
Upgrading software should be an UPGRADE - not a step backwards, sideways, or down the toilet. WTH Autocad...
Do people even test out the feasibility of these changes to MAJOR CORE features of the program...!!!
Message 9 of 13
RobDraw
That's a pretty big stretch saying it's a downgrade as this is probably more of an isolated issue than you care to admit.
Rob
Message 10 of 13
This is hardly an isolated issue. Go to the thread that I linked about the screen flashing. When one KNOWN issue is ignored by autodesk, and then that steamrolls into creating MORE issues there is a problem. Screen real estate is a pretty damned big priority in our world and to ignore issues that degrade that priority is ridiculous. We pay good money for this program, I prefer not be a sheep and just accept these kinds of things....
Message 11 of 13
RobDraw
IMHO, this is probably a hardware, rather than software, issue. It is no where near as widespread as you make it out to be.
Screen real estate a big issue? Come on. In this day of multiple monitors and large screens, you can have as much real estate as you want or can afford.
Rob
Message 12 of 13
Go away.....no one cares what you think..............not productive - just whiney
Message 13 of 13
RobDraw
So, you dug up this year old thread to try to insult me, twice?
Cheers!
Rob
