AutoCAD Forum
Polylines with width are not connected Properly
8 REPLIES 8
Message 1 of 9
Losspost
762 Views, 8 Replies
Hi I have the following Problem:
One of the images Shows two polines connected together. In the second Image I give the polylines a width. But when I it, it leads to the corner you see in the image. How can I remove the corner/ get it linked properly together. One thing I tried was flatten it and correct it manual. But because there are alot of connections doing this by hand is no real option. Any suggestions? Or if it would be possible to get the conture of the polyline?
8 REPLIES 8
Message 2 of 9
Alfred.NESWADBA
in reply to: Losspost
If this is really one polyline then it should not do that (not at this small deflection).
Can you please upload the dwg-file and let us know which version of AutoCAD you are using?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Message 3 of 9
Losspost
in reply to: Alfred.NESWADBA
I cant upload the dwg file really.
Its in Autocad2020
Message 4 of 9
Alfred.NESWADBA
Because if which reasons? I guess this polyline will not have anything to do with secrets.
If it's the "how does upload work here" ... then please reply to this post within your internet browser, below of the text field you'll find a text "Attachments" and a small paper clamp symbol ... click it and select your file.
- alfred -
Alfred NESWADBA
Message 5 of 9
j.palmeL29YX
AFAIK AutoCAD can't create a mitre between two non tangential arcs (arc segments of a polyline). Each segment of a pline arc with a width >0 ends perpendicular to the arc. I guess you have to live with this limitation (while the arcs are not tangential).
Jürgen Palme
Message 6 of 9
Yep, looks you are correct with analyzing the screenshot ;)))
- alfred -
Alfred NESWADBA
Message 7 of 9
j.palmeL29YX
in reply to: j.palmeL29YX
>>here<< a demo video and also a suggestion how to get the wished design.
Jürgen Palme
Message 8 of 9
Losspost
The Full file has some secret so I had to make one seperate first.
I cant really live with it because I am working with litography and even through the error is small it still to big for what I am doing
Message 9 of 9
Alfred.NESWADBA
Have you seen Juergens video? (I guess your posts crossed)?
Another question is when you write about lithography. When you exchange the data via PDF you might use lineweights instead of polyline widths? I know that lineweights are not that flexible, but at least they would not show these effects.
- alfred -
Alfred NESWADBA
AutoCAD Inside the Factory
