Polyline woes
Polyline woes
pw8154
Polyline woes
pw8154
I am struggling with what should be a very simple and quick operation. I have 200+ frame outlines in a drawing, and I need to convert each of them to a closed polyline so I can extrude them.
The frame profile is made up of around 6 straight lines, four arcs and a wavy section made of around 50 sections made into a separate polyline.
Many of them have worked fine - I have to take great care at the corners and joins to ensure all line ends meet up correctly.
However, I've had a few where the process doesn't work - although a closed polyline is created, it won't extrude. However, if I take that profile into a new drawing, explode it and repeat the process, it works and I have an extrudable profile. BUT, when I take that successful profile back into the drawing, it won't extrude (cannot sweep or extrude a self intersecting curve).
Can anyone advise what is going on please?
Many thanks.
u can do it through BOUNDRY  command
enter BOUNDRY
and just select the inner portion of ur polylines.
automatically urlineswill be converted as a closed polyline
Alfred.NESWADBA
Can you show that objects (as DWG)? It's difficult to speak about some geometry that does not work as expected without having access to them.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
pw8154
Thanks Nevil. Thats wonderful. Gonna save so much time now!
pw8154
Thanks Alfred. I won't post a dwg now, as Nevil's suggestion seems to be working flawlessly.
Also, I think I might send something that doesn't work in my drawing, but works for you (as it does if I create the profile in a new drawing).
I wish I'd known about this command years ago.
Alfred.NESWADBA
it's great that you already found your solution! 😉
I would like to have your drawing (erase the other entities) and not a copy of that polyline in a new drawing.
From what you tell us I agree that it might be a combination of drawing + geometry, and that can have e.g. high coordinates as reason, or something else. But again, hard to guess without having it. 😉
If you want to find the reason the feel free to upload it.
Just to make sure: if that geometry objects don't intersect or touch each other, that should be done by just one command (_PEDIT with option "multiple objects).
With _BOUNDARY you have to go for each single polyline, maybe if you know the reason about when that issue happens the result is less work 😉
On the other hand .. copying all arcs and lines to a new drawing should also result in running just one single command to get it done?
- alfred -
Alfred NESWADBA
