polyline screened back during arc command
Message 1 of 9
why is my line screened back during arc command?  it's only happening in one file.
Replies (8)
Message 2 of 9
natasha.l
Hello @Anonymous,
I would try to repair your drawing it seems to be corrupted, please review "How to repair corrupt AutoCAD files".
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Message 3 of 9
Natasha,
thanks for the response.  I will try that, but other users of the file are not having the same issue...
Message 4 of 9
Alfred.NESWADBA
I would use copy & paste the geometry from your current drawing/modelspace to a new dwg-file and continue there.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 5 of 9
pendean
Community Legend
Community Legend
Start a new file, copy/paste this into the new one: anything change?
Message 6 of 9
s.borello
Have you tried copying your geometry to a new empty .dwg?  It may solve your issue.
Message 7 of 9
the issue happens during the command, using arc or circle (not what else)
for example, when creating a circle and pulling the radius out, the line should not be screened back but for some reason it is in this file...
Message 8 of 9
Alfred.NESWADBA
That's why I suggested to copy and paste into a new dwg-file as this should solve the issue.
- alfred -
Alfred NESWADBA
Message 9 of 9
natasha.l
Hello @Anonymous,
All the suggestions provided are outline in that article. Just checking in with you, hope you were able to resolve this.
