Poly Lines Plotting differently to each other.
rob_hawkesHH2E3
Message 1 of 20
rob_hawkesHH2E3
All of the polylines should have the same global width, should all be the same line as they were created with offset. They do show as the same on Autocad, But when I plot to PDF or even preview the plot some of the lines plot thicker than the rest of them.
I've tried Object Lineweights and Scale Lineweights on and off,
Any help would be appreciated.
Replies (19)
Message 2 of 20
cadffm
Zoom more in or out,
change the viewer or just a setting (test it),
print to paper will show you: All right, it is  a PDFviewer "issue" only.
Or?
Sebastian
Message 3 of 20
rob_hawkesHH2E3
Zooming doesn't make any difference, and I have tired Adobe and Chrome to view the PDF and its the same, and always the same lines that are wrong. I'll try printing a physical copy when I can but I don't have access to a printer atm.
Message 4 of 20
cadffm
If you share two or three things, we all can take a look..
Your PDF, the the associated source DWG with this layout current and the pagesetup should set as you used for this pdf plot.
Sebastian
Message 5 of 20
Valentin_CAD
@rob_hawkesHH2E3 ,
Select all your polylines and make sure their Properties for "Lineweight" is ByLayer, and "Global width" is 1 - instead of "Varies".
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 6 of 20
rob_hawkesHH2E3
rob_hawkesHH2E3_0-1704287125369.pngrob_hawkesHH2E3_1-1704287160825.pngrob_hawkesHH2E3_2-1704287203304.png
Message 7 of 20
cadffm
You haven't responded to that yet, so I ask you:
Should we now ask every little thing possible and guide you, or do you still share your PDF and your DWG?
(In the DWG you can delete everything except these polylines)
Sebastian
Message 8 of 20
Valentin_CAD
@rob_hawkesHH2E3 ,
While we wait for you to provide a DWG and PDF, try these troubleshooting guide (see link below):
Emilio Valentin
Message 9 of 20
pendean
Community Legend
Community Legend
@rob_hawkesHH2E3 Fix the lousy default Adobe Acrobat display settings, here are mine that work 100% of the time
And if I may ask, why are these different
and are you using transparency too?
Message 10 of 20
rob_hawkesHH2E3
Sorry I was getting clearance from higher up. And as I suspected due to GDPR I cant send what I'm working on but I've just done a blank drawing and done the same thing, Draw PLine, offset several times and plot and that gives the same results.
Message 11 of 20
pendean
Community Legend
Community Legend
here is your problem (or was that just an accident on your part)
Your content is too small for the PDF format. Is your PDF recipient really and truly going to zoom in that close?
Did you lose track of your scale? your DWG in in inches, your viewport is set to 1:100, your items measure this much
Your 1:100 definition might be incorrect, seems off. Where did you get it from?
Message 12 of 20
Valentin_CAD
@rob_hawkesHH2E3 ,
I agree with Dean.
Try to use Window as Plot Area and a specific plot scale - as this sample:
Emilio Valentin
Message 13 of 20
cadffm
as Pendean said, change the printer/resolution
for example:
And re-think your visual check:
Your offset between the lines (on paper/pdf) is less than 0,3Millimeter, the width subtracted ~0.17 Millimeter!
That's far away from a useable practise (on paper).
Sebastian
Message 14 of 20
rob_hawkesHH2E3
Hmmm ok that seemed to be the problem, is there any way of fixing it in the larger drawings?
Message 15 of 20
cadffm
? You picture and pdf looks well
Your both .pdf are print to A0,
and the object size "on Paper" on 'drawing-layoutwindow is bigger than the first -there is no problem!?
(If you printed the objects smaller the problem would reappear)
Paper more large and/or objects (on "paper") more smaller => you need more resolution
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-BE373C38-678A-4AF9-96AB-4195FFD6F806
Sebastian
Message 16 of 20
rob_hawkesHH2E3
Yeah but as said the PDF and DWG are just what I can send due to GDPR. I cant plot the proper drawings on a different scale because they are an overview for routing cables.
Message 17 of 20
cadffm
>>". I cant plot the proper drawings on a different scale because they are an overview for routing cables."
I don't like to say "No", but read this again:
1. Paper more large => you need more resolution (if you have trouble with them)
2. objects (on "paper") more smaller => you need more resolution (if you have trouble with them)
and I pointed to the setting of .pc3 files (you can create your own).
What I guess, without knowing your original file,
your papersize is the same as in your sample: 841x1189
and the viewport scale is also the same (factor 0.01)
and as shown above, the resolution of the standard .pc3 "AutoCAD PDF (high quality)" is enough..
and if not, set up your own .pc3 with a higher resolution.
Sebastian
Message 18 of 20
rob_hawkesHH2E3
Changing it to AutoCAD PDF High Quality has done the job.
Thank you for your help.
Message 19 of 20
pendean
Community Legend
Community Legend
Fix what please? You fixed the viewport scale, so that would be the "fix" then (aka you might have to start new viewports or new layouts)
Message 20 of 20
rob_hawkesHH2E3
Changing the printer/plotter setting from DWG to PDF.pc3 to AutoCAD PDF (High Quality Print).pc3
I guess it was a plotting resolution issue.
