I like using Polar Snaps and Orthogonal, obviously not at the same time.
I understand why Polar Snaps are turned off when F8 is pressed to turn on Orthogonal mode.
What I can't understand is why Polar Snaps doesn't return to its original setting when F8 is pressed again to turn off Orthogonal mode.
How can I add this to a Wish List ?
Solved by Kent1Cooper. Go to Solution.
No, you may not add it to a wish list. Autodesk doesn't have AutoCAD in the idea station. *☆--<(''<)
Why? you may ask, because everything would be convenient or easy.
https://forums.autodesk.com/t5/custom/page/page-id/Ideas-Page
@Anonymous wrote:
What I can't understand is why Polar Snaps doesn't return to its original setting when F8 is pressed again to turn off Orthogonal mode.....
I agree that it would be nice, if you got into Ortho mode from Polar mode, it would go back into Polar when you turn Ortho off, so by all means, make that suggestion by whatever means you can find.
In the meantime, hitting F10 instead of F8 will get you what you're after -- out of Ortho and into Polar in one shot.
