I have imported a PDF into model space which has a title block, I want to plot a layout which shows part of the PDF in the view port. How can I plot the layout hiding the lines of the PDF border/
Solved by pendean. Go to Solution.
Thank you that command did the trick, however I still get the clip border in my plot. To get rid of this I changed the colour of the clip border to 255 and changed the colour density to 0. Is this correct or is there a simpler way?
